HydroAir System
Techman
Member Posts: 2,143
Yes ,you can add a FWA system. Cost? That's between you and your contractor.Electric, piping, duct work ,air filtration,air conditioning,humidification, dehumidify carpentry and condensate removal?????????????
Can I add a Hydroair unit to existing Forced Hot Water Boiler
I have a Forced Hot Water boiler with three zones in my 1st and second floor of my home and need heat from my basement. While I have baseboard radiators upstairs that work great I do not care for them much as they get in the way. We refinished the basement as a play room and would prefer not to have baseboard heaters installed as kid typically step on them and otherwise dent them.
Can we install a hydroair wall unit? If so how much should this cost? The finished basement is about 500 sq feet.
And for
only 500ft of basement???
Have a load calculation done and see if your boiler will support the additional load,and then you will have the math to make a better judgement.
Might be surpise and find that two panels rads would properly fit right in with the budget.
Unless acourse, you're loaded.0 -
Beacon-Morris
Make what used to be called chill-chasers,Its a wall mounted kick space heater, turbonics make one, they are a 2000-4000 btu wall mounted heater you can run by t-stat, this willkeep the cost down....
David0
- 87.4K THE MAIN WALL
