Flexible gas pipe
Rollie Peck
Member Posts: 47
I'm helping a friend install a gas fired, ceiling hung
heater in his garage.
A contractor friend got him the necessary flexible gas
pipe to connect the heater to the existing gas line.
In the process of making the connection, I noticed that
the end of the pipe was just pressed against the inside of
the connectors that came with the pipe. This does not appear
to be very gas tight.
Are we missing a gasket of some kind?
Rollie Peck
Homowner
Rollie Peck
Homowner
Rollie,...
Sounding as helpful as I can, even as plumbers we need an additional certification to install flexible SS tubing. I can only hope that you avail yourself of a properly licensed, insured, professional plumber or fitter that has the necessary experience and qualifications. I have no intention of answering your question due to the multiple liability issues and the fact that I can not directly supervise your work. I'm sorry if this sounds harsh, but I hope you understand.0 -
RP.......
This is where the regulars on the WALL get lam basted for advising with due cause. PLEASE CALL A PROFESSIONAL. This is not lago blocks and although you Q: is legit., The wrong guess can KILL someone. Even if I give you the answer,..The fact that you are unsure causes me great concern.
Mike T.0 -
Here here!!! The 'friend' who is a plumber did no one a favor by purchasing you this csst. I too went through the class and tested to be licensed to even purchase this stuff. You and your house could end up on the moon....this is your family's safety here...don't mess with it.
TimJust a guy running some pipes.0 -
Flexible gas lines?
Rollie,does this flexible gas line have the "connections"as part of the flex "right out of the package"? or is it the type that you cut to length AND then you make your own "flare" connection using the "factory certified" tubing cutter and flare block?0 -
Hi Techman:
This is a coil of CSST that came with the connectors
attached.
I am very safety conscious, which is why I asked the
question of such knowledgeable people. Considering the
other replies received, I'll hire a plumber to make the
connections once my friend has the heater hung in the garage
and the pipe run to it.
Rollie Peck
Homeowner0 -
Rollie
Wise choice!The threads on gas pipe are different from the threads of "flare" connectors.Maybe thats why your putting the fitting together didn't seem right? Happy Holidays!0
