radiant heat under wood floor
Be careful on that site. the info there ranges from pretty good to not good at all.
You can install radiant under wood. Moisture content is very important. Type of wood, width of flooring, saw method also play a part in how good your results will be. Intensity of your heating requirements (determined by a heat load calculation) also let you know how close to "hot water"... yuk yuk... you are.
I recommend checking out the RPA's flooring guide. it's $10 well spent. http://www.radiantpanelassociation.org/i4a/pages/index.cfm?pageid=246
Is it acceptable to put radiant heat under wood floors?
1 layer of OSB and 1 layer of hardwood flooring
max temps
panel sruface temp should not exceed 80 deg0 -
depends on the flooring. many are warranteed up to 850
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
