Hot water heate in a Levittown cape
I have a Levitt cape . What brand boiler do you have now ? Is the wall cut out in the hallway ? We usually install a new boiler so it can be serviced from the hallway , and an indirect or an aquabooster can be tucked in behind the boiler . I have a Peerless WBV3 and 30 gallon Phase 3 under the stairs . Snug fit , but everything is accesible . And unlimited hot water .
Upstairs in a closet is always an option too , if there's no room under the stairs .
How water heater in a Levittown cape
I own a Levittown cape, boiler under the stairs. Hot water is heated with a coil. If I wanted to put a hot water heater in does anyone have experiences where to put it.. thanks all.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
