Vapor Vacum system
David Sutton_6
Member Posts: 1,079
I was the new guy on this install in 89
This was dnoe when i first started at Krupa oil co.
We need to replace the boiler so my old company, asked if i would work with there top man Russ. Russ was my helper , now i'm his!! Man that makes me proud!!!!!
Hey Frank, the boiler going in is a 480 W+M calls for one 4" riser, there are two tappings on this boiler would it be better to use the two of them instead of one??
Thank you !!
David0 -
Why did the old boiler
only last 17 years? two risers would always be better than one, imho.
Hi Gerry
The oil co. looked at it and said the top of the rear section had a crack in it.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
