Outside smell from Oil burner
brucewo1b
Member Posts: 638
and that is to have it tested by a pro with eletronic test kit, if stronger than you remember durng the summer then please teast ASAP to make sure its normal and not sooting up.
outside smell from oil burner
I had an Energy Kinetics System 2000 (EK1) installed last May. As the weather is getting colder, I have been noticing a strong smell outside (a distinct smell I can't really describe -- maybe "sweet and nauseating"?) in the mornings while the burner in firing. Is it normal to smell the exhaust like this?0 -
Exhaust smell?
Is it power vented? You probably didn't notice it until the heating season because it will seldom run for domestic hot water. Now it's colder weather, it runs more.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
