From our friends at B&G
DanHolohan
Member, Moderator, Administrator Posts: 16,686
Bell & Gossett Unveils New DB-Differential Bypass Valve
Morton Grove, Illinois; December 20, 2006 - An innovative new Differential Bypass (DB) Valve designed to control excess flow in hydronic systems has been introduced by Bell & Gossett.
When there is a reduction in demand, the new valve acts as a bypass while ensuring adequate flow to the remaining open circuits. Designed to be used in systems where heating loads may be excluded from the circuit as zone valves close, the differential bypass valve also helps reduce velocity noise caused by excess flow through the circuits while maintaining the pump head at a constant valve.
Developed for hydronic systems utilizing zone valves, the new valve offers the following features:
* 3/4" connection
* All brass body with non-ferrous internals
* Horizontal or vertical installation
* Maximum working pressure 150 PSIG
* Maximum operating temperature 230 degrees Fahrenheit (110 degrees Celsius)
For more information, visit www.bellgossett.com.
About Bell & Gossett
Bell & Gossett, a unit of ITT Corporation, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
* 3/4" connection
Retired and loving it.
with ur connection to B & G
Did ya tell them to put the bolts back in the circ pump boxes?0 -
I have no influence
I just post press releases as they're sent to me.
They do read the Wall, though.Retired and loving it.0 -
Don't bother, it's...
...MADE IN CHINA0
