Gorton #2
Guest_5
Member Posts: 35
Not sure how long the main is. I'll have to check once I get home.
But I do know its a 2" pipe as I recently insulated it with 2" fiberglass tubings.
Gorton #2 or #1
Hi.
I have a question in regards to main venting.
Currently, my long main running to the cold side of the house has a Gorton #1 on it. It hisses after the pipe and radiators are hot.
Should I get the Gorton #2? If so, woul dit fit? The gorton #1 is 3/4" x 1/2" (as seen here: http://www.pexsupply.com/categories.asp?cID=302&brandid= )
But the Gorton #2 has no dimension specified by PexSupply. I want to make sure it fits into the nipple.
Want to make sure before I order, as they cost about $50 each and don't want it to be wasted because they don't fit.
Thanks.0 -
also..
I forgot another question I have in mind:
I can't seem to find the short main. I can easily trace and see the pipes of the long main going from the back of my house to the front and thats where my Gorton #1 is located at.
Is it normal or fine for not having two mains?0 -
Gorton vents
A Gorton #2 is 1/2" MPT. You could Tee a couple of #1s together and get about the same venting as a single #2. This way you use what you have and pay a little less for what you need.
If there's only one main
getting all the steam from the boiler, you need a lot of venting to get the steam to the end of the main before it starts rising to the rads. How long is the main, and what pipe size?
"Steamhead"
#1 vs #2 Gorton Vents
Steamhead says that a #2 is the equal of 4 #1s.0 -
What do I need...
to install a Gorton #2 onto the main besides drilling? Is there an adaptor to fit into the current fitting so the #2 can be installed?0
