Reading a pressuretrol--dumb question?
Larry in Phila
Member Posts: 6
This may be a dumb question--but where dors the dial read the "Cut-out" differential on the standard little gray Honeywell Pressuretrol, like the one pictured in "We've Got Steam Heat"? It's actually not clear where the "1" should be aligned at for a 1 pound differential, and of course I have no owner's manual.
If you can relate the answer to that photo, which has an arrow that may or may not mean this is the spot to measure pressure, that would probably make the answer clearer.
PA404
On the PA404, the number that's facing the front of the control on the differential wheel is the differential setting. You turn the wheel all the way to one side for a differential of 1psi.0 -
pressure
Cut out is 'cut in' plus the 'diff'
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
