oil burner makes high pitched sound
Kevin_52
Member Posts: 8
I just got a customer comlaint that the oil burner was making a very high pitched sound, then it would go off in reset. Any preliminary suggestions?
Check
Oil filter, pump strainer and oil lines for restrictions provbably one or all three plugged.0 -
pump noise
If it is cold out, gelled fuel or gelling in lines will do it.0 -
water ...
lots of gunk on the oil fan blower motor squirl cage,....
furry creature wrapped around the pump /motor shaft...
ice...
thick / gelled fuel...
tank lines far from ideal...
are some ideas to check...0 -
yet more..
dirty tiger loop with a hair-line crack in the top.
ss
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
