hot water zone getting hot
Lakota_2
Member Posts: 4
upstais zone getting hot when not calling for heat. replaced flow check and that didn't work. could it be getting hot thru return side
Could be...
Flo check float tightened down?
Thermostat problem? Short in wiring?
Is the circ running, or is it thermosyphoning?
Some guys here have HAD to put flo checks on both supply and return. Just some ideas.
It all depends on the piping layout near the boiler. I typically put them (checks) on both sides and have never had a migration problem...
TimJust a guy running some pipes.0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
