Furnace Temperature
Empire_2
Member Posts: 2,340
The usual temp rise is 40 to 70 or 80*. There is a tag on the side of the furnace that states what that system will produce IF designed properly. 70* in plus 60= 140 Supply. Approx............ Restricted air flow will produce higher temps.
Mike T.
Mike T.
Forced Air Furnace Temp
What is the normal temperature of air going into the supply air duct of a residential gas forced air furnce?0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 986 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
