Meter for No Burst
Nick L. in Vt
Member Posts: 87
Got mine at a Bond auto parts shop for $58 bucks, have used it for a year and tested it against $300 model. It works great, we use cryo tek and no burst.
No Burst checker
Is there a reliable, inexpensive meter that will reliably give antifreeze percentage and degree of freezing. would like to put on in my tool box but don't have $300-$500 kicking around in my ash tray. Thanks to all the wallies0 -
Refractometer
Hach Chemical makes one I think. Simple floats like you use to check for car anti-freeze. Not sure if Noble No Burst has a different degree. (Seems like propylene in some ways but behaves better in some respects.) I take it Noble recommends the electronic version?0 -
Refractometer
Grainger sells a portable refractometer for anti-freeze. Their stock # 3MY57 made by Extech.
-Jared0 -
Test Noburst
You should use a refractometer that measures Propylene Glycol. The floating ball testers are not very accurate. You can find the instrument that we sell at noblecompany.com, then click on store. It will direct you to the refractometers. You can also search the web with , refractometer/propylene glycol.
If you have more questions call me at 800-678-6625, Ext. 108
Drew0 -
cheap refractometer
I got mine at Bond auto for $58 and have used it for a year. Works great and have tested it against $300 model. We use Cryo Tek and No Burst.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 977 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
