tekmar 152 -4 slab sensor
clammy
clammy Member Posts: 3,242
Wondering how acutrate a surface mount sensor would be for a garage slab i didn't rough it and after a little reasearch found it to be a little shy of the lose and they are also looking at a/c for the garage so i'm proposing to do a hydroair to make it up and also warm the place after the 18 ft by 9 ft door opens ,but here's the catch there no rough in for a in the slab sensor so i was wondering how well a surface mounted sensor maybe expoxied to the floor would work .I am planning to use a fixed mixing valve for the radiant and uses a munchkin t80 wall mount boiler and a vision one controller size the hot water coil for lower temp about 140 with a variable speed air handler also there a 2 nd floor apartment which will be baseboard and sized for the lower 140 water temp .I know i could use the vision 2 and some 3 way valves but i don't think that is in there budget and as things sit now this whole set up may be over there budget .On the same page the a/h and boiler /indirect tank are all in a very small foot print under the stairs with the electric panel super tight .Plus the radiant is vega 1/2 300 ft loops and only 3 loops on 12 centers doesn't even meet 1/2 the heat lose poured without pressure test applied aside from all that what,s any one experence with surface mounted slab sensors thanks ,good luck and peace clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
