Boiler condensate
Brad White_9
Brad White_9 Member Posts: 2,440
about the marble chips right in an over-size receiver, Hot Rod.
The "outdoor discharge" thread, now that I recall, was to a dry well, sleeved below ground and below frost line, so a good point of reminder.
Now, if I could only harness the hydrogen resulting from the neutralization process into something useful like a fuel cell or dirigible... :)
  • saxman251
    saxman251 Member Posts: 17
    How do I....
    I am putting in a w-m ultra 80 boiler, and I cannot figure out what to do about the condensate. Boiler is in the basement, but there are no drains down there (washing machine is on 1st floor on other side of house from boiler). The only waste plumbing anywhere near the boiler is the cast iron main. Any suggestions?
  • Timco
    Timco Member Posts: 3,040
    Use a condensate pump to get te water to the stack & cut in a 'Y' and a p-trap or pump it outside. Here in SLC you can pump it outside.
    Tim
  • Brad White_26
    Brad White_26 Member Posts: 35
    Don't drink it :)
    You will have to pump it and if cast iron drainage, neutralize it.
    I used to use a drywall commpound bucket (thought it was PVC, I think that they are HDPE plastic). Filled it with marble chips and had a 1.25" tapping out the side to a Little Giant disposal pump. The PH came out close to 7 maybe 8 if it sat a while. (Starts at about 4.5)
    Come to find out the condensate attacks the plastic that drywall buckets are made of, turns it brittle and sharp. Amazing. So now PVC or CPVC pipe is recommended. A piece of 4" tube 18 inches long with a pair of 4x4x2 tees, one at each end and a cleanout plug at each end to fill it with marble chips. Inflow into one of the 2-inch tee tappings and the outflow out the other, rotated 180 degrees from the first. To the pump and out she goes.
    Another thread a few weeks ago had the effluent go outside to a blueberry patch and made the most incredible blueberries. Who knew??
    When you connect to the drain, make sure you have a trap seal and indirect waste stack with an air gap and vented.
  • grindog
    grindog Member Posts: 121
    condensate pump
    put in a condensate pump and run it over to the cast iron main. cut in a trap and make sure you at least put in some type of mechanical vent if you can not do so traditionally.
  • hr
    hr Member Posts: 6,106
    You might
    find a condensate pump with a large enough capacity to add some marble chip right in the container. Little Giant offers a lot of different models.
    It's usually easy to pipe that small condensate line over, and into to a washer standpipe drain. Or add a Y branch tailpiece under a sink drain. Might be easier then getting into a cast iron soil pipe, especially a legally vented connection :)
    I'm not sure about outside. Could be a freeze issue, and at low temperature operation they make a lot of "water" My 80K Lochinvar would nearly fill a 5 gallon bucket in a days work. That, on a daily basis, would be more than your frozen lawn would like to see :)
    hot rod
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Condensate for Blueberries
    Might have to try that during the non-winter months. I've wanted to grow blueberries for long time, but soil here is naturally quite alkaline.
  • Ted_9
    Ted_9 Member Posts: 1,718
    Marble chips
    So, where does one buy marble chips? What else can be used?
    Does anyone have a picture of their neutralizing kit?
  • Brad White_9
    Marble Chips
    Being half-Swedish and six feet tall, I just walk in a low-hangng crawlspace and -BANG- get all the chips I need :)
    Garden supply house, Ted. You could probably use any kind of limestone but not powdered lime. That would form a cake of cement.
    Once spent, the chips are rounded and relatively smooth with little pin holes. If you listen carefully on a still night, you can hear the Alka Seltzer jingle...
    I really should detail the neutralizer and post it. Let me get on that. PVC pipe, tees and cleanouts.
