Lowering pressure on boiler
Brian_42
Member Posts: 3
Hi,
Just purchased a home with steam heat. Purchased Dan's book and did lots of reading on steam heat. I puchased and replaced a few radiator air valves and checked the main air valves for proper air flow. All seems ok but when the system is raising the temp in the house significantly it seems like there is exessive noise (hissing) at the radiators. Can I try lowering the pressure myself? I am fairly mechanical and I have figured out how to to it, I am just unsure if turning the screw on the control is all there is to it.
The pressure now is hovering just over 2 p.s.i.
Any help greatly appreciated!!
Brian
Brian
you got it, drop pressure setting to 1/2 psi and see if it helps.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
