utica dv
keith_12
Member Posts: 15
what kind of readings should i be looking for at the flue outlet with a combustion analzer.
utica dv boiler
any numbers out there for stack temperture,o2 and co at the flue outlet?? for natural gas direct vent boilers.0 -
http://www.bacharach-training.com/CO Zone1/Flue Gas CO Test Procedures.htm
Good read but hwat your looking for is at the bottom of the page0 -
Keith
What numbers did you get?
I'd give you the "Real numbers", but what will you do if those numbers don't match up?
Tell me what you have found so far.
Mark H
utica dv boiler
mark here are the readings at startup, o2-15.1 ,co2-3.2 ,co-400 , flue temp-282 , ambient temp-56. the readings are from the flue outlet at the boiler.0
- 85.9K THE MAIN WALL
- 51 Biomass
- 420 Carbon Monoxide Awareness
- 78 Chimneys & Flues
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 883 Plumbing
- 5.9K Radiant Heating
- 377 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 40 Industry Classes
