Monoflo Tee's & Kickspace heaters
![Mark Walsh](https://secure.gravatar.com/avatar/2a80211a3c0c4451233901fd57f2cfd2/?default=https%3A%2F%2Fvanillicon.com%2Fb42248fb75a4cce91a769f04ac37107a_200.png&rating=g&size=200)
Mark Walsh
Member Posts: 1
I have recently purchased a Kickspace Heater to suppliment the SlantFin Baseboard raditors that are at the far end of my kitchen.
I have 3/4 inch line feeding the last 3 ft baseboard before returning to my boiler just below the location where I will install the Kiskspace Heater. The heater will be installed about 10 inches above this main.
The question. Should I install 1 or 2 Monoflo Tees. If one should it be on hte supply to the heater or its return? Any reason not to install 2?
Just one...
The diverter tee should be on the return. Don't space them too close or it will make some noise and not have much flow through the new branch.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
