Steam Radiator Venting
M.Naughton
Member Posts: 4
Whenever the boiler fires, air rushes out of the vent but only for barely a second before I can hear the float needle closingly firmly against the seat.
Pressuretrol's cut-in is set 1/2 psig. I'm not sure about the drop-away pressure on the vent since I don't have access to the specifications.
The radiator is a small Burnham Baseray Radiant Radiator. The radiator is sized for the small bathroom but it doesn't necessarily heat up the room as expected.
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
