Munchkin questions
Guy_6
Guy_6 Member Posts: 450
The vapor is a normal occurence, but the noise concerns me. I would make sure that the gas piping is being supported by something other than the gas valve. I have seen that create noises (and broken fittings).
  • Howard Hess
    Howard Hess Member Posts: 1
    How loud should a Munchkin be? How much vapor in the exhaust?
    Hi everyone,
    My two-week-old Munchkin 199M seems louder than the ancient Weil-McLain 260,000 BTU monster it replaced. It's definitely louder in the boiler room, and as far as I can tell the noise is coming from the boiler enclosure, not the circulating pumps.
    I'd describe the noise as a thrum, with a noticeable dip in the sound level every second or so ... thrum .. thrum .. thrum.
    I can also hear the sound at night in the bedrooms ... where with the old boiler I might have heard water circulating, but never a thrum.
    The other question I have is how much moisture should be coming out through the exhaust? Today was our first day in the low 30s with this boiler, and I was surprised to see big clouds of vapor coming out of the vent ... kind of like the vapor that comes out of the clothes dryer at the start of a load of towels. 8-)
    I'm wondering whether the noise and vapor are signs that the boiler may not be adjusted properly. I'll be calling my contractor, but I thought it might help to tap the collective wisdom here.
    Any insights would be greatly appreciated.
    Thank you,
    h2
  • ScottMP
    ScottMP Member Posts: 5,882
    Yes, its normal
    Wait untill it gets cold :) You'll really see it. Check out the photos here. I labled them as freeze-up only because they are winter pictures, not because of problems.
    You do need to get your contractor back. It sounds like he did'nt set up the combustion correctly.
    Scott
