Relay for Elec Tro Temp boiler
tHEY SHOULD BE ABLE TO HELP YOU. eVEN IF THEY HAVE TO CROSS MATCH THE RELAY, IT SHOULDN'T BE A PROBLEM.
  • Relay for Elec Tro Temp boiler
    I have an older Elec Tro Temp boiler that the relay sounds like it is going bad. It is made by Oak Industries and the data on it is such:
    Cat# WUO24A1-404
    Coil 24 VAC: 50/60 CPS
    Load 25 A, 240 VAC RES
    1 HP, 120 240VAC 50/60 CYC
    Have any idea where I might find one of these. I am sure this is old enough it may be tough. Thanks, Don
  • carol_3
    carol_3 Posts: 397
    You can replace it by function (the specs you describe). You don't need a like-for-like replacement. Probably couldn't find it anyway!
