peerless boiler
Boilergeek
Boilergeek Member Posts: 42
You can get a bronze 2" VJR200 it will handle up to 40GPM, and they are cheap! arround $170 from your local supplier.
A 2" seinior will get you up to 50GPM VSR200
Any higher flow you would need a high velocity 2"
It would get to 100GPM
A Spirovent is an excellent choice for any Hydronic system
  • ralman
    ralman Member Posts: 231
    peerless boiler
    My peerless boiler has a 2 inch iron supply pipe. I have been reading that a spirovent would be a good air eliminator to install but they do not go up to 2 inch. Should I reduce to 1 1/2, install the spirovent and then use another reducer to connect back to my 2 inch pipe which is 18 feet long? I would hate to replace it. What are my alternatives?
  • Is this a gravity hot water system ?
    Is there a circulator on the boiler somewhere ?
