Radiant heat zone
I have a hot water boiler with baseboard heat.And I would like to add one zone of radiant heat. is there a special control that lowers the water temp in that one zone?
  • Weezbo
    Weezbo Member Posts: 6,231
    one of the simplest is an I series R zone valve
    and a set point I series S bypass, to control return water.
  • a taco mixing block can be a good way to do it as well.
