checkvalves
hr
Member Posts: 6,106
should have info showing the Cv of the valves. The Cv is the GPMs the valve will flow with a 1 psi drop.
Most often using a check the same size of the pipe is over sized. You should select the check by it's flow rate for noise free installations.
I like the soft seat, low pop pressure checks. Conbraco, Watts, and most other valve manufactures offer this type. And a cone shaped check is better than a flat disc type for hydronic applications.
This is a check from the Grundfos Super Brute circulator. Cone shaped, light spring pressure.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
checkvalves
Is there any difference in pressure drop or other performance variables between standard swing checks, "Y" pattern and ring checks? thanks ahead of time.0 -
It takes very little pressure to open a center spring silent check valve. And they work in ALL positions.
TJust a guy running some pipes.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
