Radiators
Timco
Timco Member Posts: 3,040
Since a HW rad only gets up to 180*, and maybe 25 psi, maybe JB weld or a similar product. Maybe a MIG weld?
T
  • Joe Cothren
    Joe Cothren Member Posts: 1
    Leaking radiator
    Have a pin-hole in one of the hot water cast iron radiator sections. Is it feisable to remove the section and reclamp the radiator back together and modify the piping or will it take a replacement radiator? The house is old and the odds of finding a replacement section may be low. The radiator heating system most likely was installed in a house modification, when the "coal fired fireplaces" became obselete. What is your suggestion for a fix?
    Thanks,
    J
  • bob young
    bob young Member Posts: 2,177
    pin hole
    if the pin hole is accessable you can drill & tap it . say 1/8 "
  • Tony_23
    Tony_23 Member Posts: 1,033
    I've seen
    HW rads get to 200F and over 30PSI :)
    MIG isn't really an option. Brazing maybe, with a skilled torch and EXPERIENCE.
    Taking out a section could cause more troubles and isn't as easy as it looks.
    JB weld might hold if done correctly, acetone etc.
    Drilling and tapping sounds like a good idea, with the right pair of hands and eyes.
