GB-142 Number 5
singh
singh Member Posts: 866
Nice work! I like those pipe supports, what are they?
Also I don't see a flo check for the DHW pump?
  • Brian
    Brian Member Posts: 285
    GB-142 Number 5
    I can't say enough about these boilers.I've already installed 2 more since and have 3 more to do before the end of the year.
    Dobber
  • Uni R
    Uni R Member Posts: 663
    GB-142
    Nice work Brian! That indirect looks local. ;-)
  • ScottMP
    ScottMP Member Posts: 5,882
  • John McArthur_2
    John McArthur_2 Member Posts: 157
    Very nice work. I like the pipe supports you used on the vertical runs.
    Our company is slated to install about a dozen of these little beauties over the next few months. I love the clean installation.
    Thanks for the pictures.
  • Joe@buderus_2
    Joe@buderus_2 Member Posts: 302
    Condensate Drain
    The exhaust piping should have a 90 degree elbow and a drip tee as close to the GB142 as possible, then 90 degree up. Please contact us if there are any questions.
  • Brian
    Reply
    Hi Uni
    It's great to see your comments lately.How many clicks did you put on the bike this year.The indirect is an Aeroso and I believe there brought in from Norway.Great unit,been using the 50 Gal.for years.This is the first 75 gal I've installed.
    Joe.
    The vent goes straight out the wall.It doesn't make sense to to add another 90 and therefor increase the linear feet of the vent just to service 3' of pipe.Will call you tommorrow to discuss.
    Singh
    The supports are called ringstays or standoffs.They are quite common in Ontario.You order for the pipe dia. required in long 21/2"centre or short 11/2" centre.It allows the pipe to expand and contract without wear.
    Dobber
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Flow check
    Hi Singh,
    That looks like a 15-58fc for the indirect.
    I was sent some pics of your work by SupplyHouse Rick.
    Very nice!
    Mark H
  • Gene_2
    Gene_2 Member Posts: 59
    Nice job.
    I agree that it doesn't make sense to add pipe or extra 90's just to add the condensate drain in the exhaust.
    I spoke to Steve Grady from Buderus and he agrees as well. Short run, no problem.
    Mark H
  • Brian
    15-58
    You have a keen eye Mark.I use the 15-58 almost exclusivly on residential.It's nice only having to carry only 1 pump that can do so many jobs.
    Dobber
  • singh
    15-58
    And is the 15-58fc enough for the indirect
    and GB?
    Just curious, Buderus recommends the 26-64 for their ST150
    how does your indirect compare in relation.
    Thanks Mark, and your work is very nice as well,being that
    your nearby, maybe one day we'll run into each other.
  • Mark Hunt
  • singh
    Lunch is on Supply house Rick!!
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Mark & Devan
    Lunch is always on the supplier isn't it!
    Of course I would. Loyalty is always rewarded...
    Rick
  • Joe@buderus_2
    Condensate Drain
    Steve Grady was refering to a "short" run as follows; off the exhaust of the GB142 a PVC street elbow is installed right at the exhaust connection and a run of six inches of straight pvc pipe is installed to get outside and terminated. No other fittings or lengths of PVC pipe can be used. We are still in the approval process of this type of vent installation. Please contact us if there are any questions.
  • Uni R
    Aeroso
    Brian,
    Probably too many clicks if you ask my better half... maybe 6 or 7k on sactioned rides. I can really feel my fitness level falling every week since the season slowed down in September. Now it's home reno and pizza season until April. ;-)
    I believe the Aeroso tanks are made here in Mississauga. It was a joint venture with a company in Norway (they supply the heating coils). I never realized that Bradford-White bought them out 3 years ago until I went to look them up.
    Keep up the good work.
  • Simply Rad_2
    Simply Rad_2 Member Posts: 171
    Buderus GB installs
    > Our company is
    > clean installation.
    John
    I think you are the John I know, in Steamboat. I saw your post on heatinghelp. So you are now installing the GB they seem like a great unit. Sounds like you have a bunch to install 12? I have been on the Vtodens kick. I am on my 5 this year. I love them too. I just got back form Viessman Academy in Vancover-what a great taining semair.
    Here are some pic from an earlier install this spring. Do you recongnize the house on short st.
    Take care Jeffrey
