Circ Sizing
A.J.
Member Posts: 257
> I was at a seminar the other day and they <BR>
> suggested sizing the boiler to a heat loss. This <BR>
> will normally make the boiler smaller than the <BR>
> system size. An example would be a 90,000 btu <BR>
> boiler and 140,000 btu's of radiation. They also <BR>
> suggested primary secondary. I assume the boiler <BR>
> circ should be sized for the boiler. Is the <BR>
> primary circ sized for all the connected load. If <BR>
> all the secondary circ's are sized for the zone <BR>
> with a 20 delta tee, the primary circ would be to <BR>
> small if all secondary zones are running. <BR>
<BR>
<BR>
circ sizing
I was at a seminar the other day and they suggested sizing the boiler to a heat loss. This will normally make the boiler smaller than the system size. An example would be a 90,000 btu boiler and 140,000 btu's of radiation. They also suggested primary secondary. I assume the boiler circ should be sized for the boiler. Is the primary circ sized for all the connected load. If all the secondary circ's are sized for the zone with a 20 delta tee, the primary circ would be to small if all secondary zones are running.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
