gravity system
Steamhead (in transit)
Member Posts: 6,688
you used the wrong column. The 17 GPM was for a modern system designed for forced circulation, without all the extra water in old gravity pipes. I would have used the NRF-33 or Taco 0010 on that system.
But if it's working for you, don't change it!
Replacing boiler for gravity system
What would be the best way to pipe a replacement boiler to a gravity system?.0 -
see ....
the heating Q&A section at the upper left...kpc as Dan says..."wander off the wall" kpc
And
pay close attention to the size of the circulator. Go here for more:
http://www.heatinghelp.com/newsletter.cfm?Id=1250 -
I just looked up that article. You know its funny that I did a circulator switch to a NRF-22 on my gravity system from an older P series 1 1/4 (I don't remember exactly, but I think that's right).
What a difference. I have about 1,100 EDR and the spec on the chart is just under 17 gpm. The NRF-22 filled the bill. And it really works well. It heats much faster.
I recommend it.0
- 87K THE MAIN WALL
- 57 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 388 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
