Stainless exhaust pipe 8\"?
Brad White_201
Member Posts: 52
(the Metalbestos folks), offer a single-wall pipe system in stainless and AL29-4C, I believe. Selkirk is an umbrella company for Heat Fab and other system manufacturers so there is a lot to look at.
I do not think that you can buy directly on-line unless via one of their partner distributors.
http://www.selkirkcorp.com/products/venting.aspx
Do you have a source online for this pipe, I get concerned that I see tiny leaks in my existing galv stuff around joints, and wanted to replace the pipe, and saw the very nice pics on here of the german home with what appears to be 8" galv pipework, which seemed to me that if I am going to replace this pipe it might be worth getting something very nice
Tiny leaks??
As in Rust? Maybe white stuff too?0 -
Derheatdude is onto something. You really need to figure out what is the cause of the leaks...they just should not be there. That is more important than installing a pipe that can survive under incorrect conditions...and that pipe will be VERY expensive...
TimJust a guy running some pipes.0 -
You need to get a pro in there to inspect the entire chimney and appliance, perform combustion analysis and make recommendations.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
