Thanks for all the help
john_58
Member Posts: 37
I would like to sincerely give thanks to all who helped me diagnose a boiler problem I had. About a month ago Jim Sokolovic, Glenn Harrison, Michal, Uni R and others helped me solve an expansion tank problem for an old converted gravity feed system in my home. The system now works flawlessly with the correctly sized and placed exp. tank. Just a note though, even until the end, my heating contractors said that a 50 psi prv would have solved the problem for a lot less money!!! Goes to show eh? My system now from cold up to 160F varies only 4psi. Again, Thank you.
Glad to hear we could be of help!
And thank you for taking the time to let us know our help and suggestions provided a solution to your problem.0 -
any time
you know, thats what we are all here for, helping each other, thanks for sharing the posts, at least i learned a thing I was taught in engineering school, remember your units when converting, LOL great to know we helped you.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
