Testo 310
njtommy
Member Posts: 1,105
Any one using the testo 310 combustion analyzer?
Thoughts or problems with it. I would only be using it on resi boilers for oil, NG and propane.
There good but not really practicable if your going to be using it a lot. I would suggest getting the 3201
No problem @njtommy, the 310 isn't designed for everyday use, 320 is much easier to use too0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
