Foreward thinking?
Tinman
Tinman Member Posts: 2,808
Steve Minnich
  • JUGHNE
    JUGHNE Member Posts: 11,069
    Good working space for the electrical, easy to trace wires. ;)
  • lchmb
    lchmb Member Posts: 2,997
    NICE!! I think I found your electrician in NH...
  • JUGHNE
    Now the pump replacer has a good space!
    And the electrician has a well grounded reference point for his armpits. Should not harm any electronics with static discharge from him or his tools.
  • Gordy
    Gordy Member Posts: 9,546
    edited April 2016
    Now that is a first..............zone valves and pumps on the same circuits.
    Where's Steamhead?
    There was not an on off switch on the pump. What to do?
    At least they put isolation valves so you can service the pump, and the zone valve with out draining the system. Or another way to stop circulation if the zone valve is stuck open. Genius......
    Steamhead Member Posts: 16,866
    Where's Steamhead?
    All together now.............................
    Consulting
  • bob_46
    bob_46 Member Posts: 813
    edited April 2016
    what's wrong with this set-up ? The guy just prefers zone valves to flow control valves. I see an on off switch for each zone. He's probably controlling the pump relays with the end switch and the boiler is either hot or reset.
  • SWEI
    SWEI Member Posts: 7,356
    No need for all those pumps once you have zone valves. A single ECM circ could handle the flow and probably knock 80% off the electric usage, not to mention 2-4 hours less installation time.
    Paul S_3
    hot_rod Member Posts: 22,192
    Yeah, add the power consumption of those PSC motor pumps and the 1.2A each ZVs. One could almost heat the home with the electricity consumed by those assemblies.
    Rich_49
