Recommendations on dual Temp/PSI gauge
Scott_Mountain_View_CA
Member Posts: 202
I need to replace an old dual Temp/PSI gauge on my hydronic boiler supply piping. The gauge will seat on a vertical 1/2" copper pipe, so the gauge needs to have a back attachment, preferably 1/2" NPT. And the gauge stem should be short and not one of those long ones (Plan is to insert a tee with a 1/2" female NPT connection out the side) The dual gauge should register at least up to 100 PSI and 220F water temp.
Can anyone suggest a gauge that fits the need? I'm willing to spend to get reasonable accuracy.
Thanks.
Thanks.
Look at Dwyer , also WintersYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
I looked at Winters on Supplyhouse.com but didn't see a dual gauge that fits my specific requirements. I don't see any Dwyer gauges fitting my need.0
Marsh Tricator try Controlco in the city
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
