Mod Con, Baseboard & Convectors--move the boiler?
Fulham
Member Posts: 5
Here's a thought.
I have a monoflow system. Boiler>>12' fin tube baseboard>>4 convectors>>16' fin tube>>boiler.
What if I move the boiler (probably not all that hard), and put all the baseboard at the start of the loop, then through the convectors & back to the boiler? Baseboard is in the living/dining room, convectors are bath, bedrooms & finally kitchen if I move it.
I'd have to reverse the system so all the monoflow valves would have to move too...
Better for heat & condensing, or not worth it?
Thanks--your expertise is awesome!
Get a 6 port manifold with balancing valves , hit each piece of heat as a homerun and make every room comfortable .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Why spend all that effort and money to upset something that works? You can ad a trv on each rad and convector to increase comfort for much less dollars!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
