How's this header?
JohnNY
Member Posts: 3,231
Good?
Aside from what's in the picture, there's no Hartford Loop and most of the system piping is copper behind the walls of this new renovation, but hey, waddayagonnado?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Atrocious. They want to fix it?0
at least there are unions there to allow it to be broken aprt easy enough....0
I would have no problem saying, see ya later have a nice day…Clearly the boiler piping has issues, near the boiler…But what is as bad, is what they did with the pipes in the wall,during the so called renovation…As well as from the pic it looks like a tight space down there….Make up air, is lots of time a killer issue after the homeowner/ carpenter decides to add a playroom in the basement…Laws and codes are not there just to make towns and cities money…They are in place to protect the public…..2
It's not leaking? Is it? So that's a plus!
P.S. @JohnNY you need to add a [/url] at the end of your signature. Your signature is showing up wrong0 -
Everybody knows, you have to put arrows on the pipes, so the steam knows which way to go...lol0
It needs to be add to The Wall of Shame post.Two-pipe Trane vaporvacuum system; 1466 edr
I don’t think piped like that even the steam does not where to go, if there is any….Besides that installer for sure can’t put the arrows on…Why, because he hasn’t a clue LOL0
Classes0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
