Hydrotherm Celtic and a 15-42
kcopp
Member Posts: 4,433
Anyone out there on Wally World have an older but still operable Grundfos 15-42? Say from the mid to late 80's? I have a customer here in NH that has a Hydrotherm Celtic 50k input, that still works perfectly fine. Mfg date 3/1984. Some other contractor decided to replace the circulator. Instead of searching for the right one he installed a 26-99 in the frame that is built into the boiler...a newer 15-58/42 is too small. Now they are having air issues because the 26-99 is way oversized.
Look Here
Personaly, I would replace it, but here is a link
http://www.celticparts.com/celticparts_list.html
Rob0 -
Ya I saw that one...
I cant see replacing a boiler in such a small space, that does not cost a good deal to run and runs fine. Sort of like ditching a car because it needs 4 new tires.0 -
Tires
I here ya, but if my tires cost $275.00 each (expansion tank). I would consider getting somthing cheaper That site is highway robbery!!0 -
Have you tried
calling Grundfos to see if they still have parts? Someone here ought to have a "clueful" contact on the inside.0 -
Yes I have....
my salesman checking w/ Urell. Yes pricing there is Nuts....0 -
Will the 15-60
I don't know what the pump curves are for the old 15-42 but this seems to be a Celtic replacement (I certainly wouldn't buy it from Europe ?
http://www.shkshop24.de/en/By-Brand-Manufacturer/Hydrotherm-Stiebel-Eltron/Circulation-pump-UPS-15-60-3-stages-Hydrotherm-HCA-25-16.html
Rob
90 -
LOL...
If I cant find one soon I am going to see if I can go in a find a way to adapt over the piping that is there and see if I can add a new circ outside of the cabinet.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
