Any Viessmann pros have a spreadsheet on Vito parts
GW
Member Posts: 4,693
Hello, I have a bunch of Vitodens out there. A series and B, 100 and 200.
It's apparent that many of the parts are interchangeable between several sizes of the same model.
My local vendor has plainly opted not to stock many parts; that's a different conversation (yes, they are happy to sell boilers, but not stock parts). The rep says there is no sheet available.
In an effort not to take over the wholesalers line of work and stock redundant parts, does anyone have a sheet of any sort that identifies whaich parts can be crossed to several boilers?
Thanks, Gary
Thanks, Gary
for example
The LGM29 on the A series 200 fits every boiler in the line up, but the radial fan is different for every size.
The gas valve is the same for the entire line up.
Gary0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
