Side Entry Pressure - Temperature Gauge?
ced48
Member Posts: 469
Does anybody make one?
You mean tridicator??
LIke this one?;
http://www.omnicontrols.com/prod-TRI_200_25E_3__TRIDICATOR_0_20-56916.aspx0 -
Yes, But with Side Entry,
not bottom entry-0 -
guage
Weil Mclain (Pex Supply sku- 510-218-099 )There was an error rendering this rich post.
That One Is a Back Entry
but thanks for trying- I am beginning to think one does not exist-0 -
Not a big fan of multi-purpose gauges
any way to fit separate temp & pressure gauges there? Plenty of options then.0 -
exactly what....
exactly what are you TRYING to do here... evidently.... not what any boiler manufacturer intended or you would have found one.
Your going to have MacGyver TWO separate gauges to do what you want cause it aint out there.0 -
Examples of Separate Temp Pressure Gauges
with side entry? How about a remote reading gauge?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
