ID this item.
Chuck_17
Member Posts: 143
Located in a school with a two pipe steam system (vacuum). There are more than one. I am sure I have seen it before (and probably knew what it is at some point).
if you can get me
the info written on it i may be able to locate its patent for you.gwgillplumbingandheating.com
Steam
Where is it attached to the system?0 -
Outside Wall
It is on the inside of an exterior wall. There at least two in the relatively small school.0 -
It looks like
a diaphragm.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Piping Size?
What size is the piping into the device?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
