1940ish boiler
Jeff Perry_3
Member Posts: 99
Started a boiler replacement, after waiting a week for asbestos removal. It's a 9 section National hot water boiler. We popped the sections and this is what the return passages looked like. They both looked like this. i wonder just how much flow there was really going on here.
Old boiler deposits
How could that boiler have accumulated so much debris, even after 70+ years?
Surely it's a closed system.--NBC0 -
Mud
...because the maintenance tech comes in every year and flushes the system. Water is like a battery; it needs to be recharged every year, right?0 -
Yep
it's a closed syste. And since the feed was tied into the bottom rear of the boiler it was also plugged solid. As was the drain. It was fun getting the system drained down, I'll tell you that.0 -
Tech?
You're kidding, right? This is a frat house. I doubt this thing has been looked at once in the past 10 to 15 years. maybe. And since the fill and drain were also plugged solid we know that even if they were showing up they sure didn't drain anything.0 -
My guess....
This neglected red headed step child with freckle and a bad attitude boiler sat down in the boiler room for years, operating "maintenance free".
The expansion tank became water logged, the relief valve did its thing every fire cycle, the make up valve did its thing every cool down cycle, and the boiler water ways lost...
If it ain't broke, don't fix it, and whatever you do, don't go looking for trouble... (Maintenance departments credo/modus operandi)
Did you happen to test if for combustion efficiency prior to taking it off line? I'm guessing it had a higher than normal stack temperature.
Our jobs will never be in jeopardy...
METhere was an error rendering this rich post.
No test
This boiler hasn't worked in a year. They went through this past winter by using the alcohol heating method. Drink more beer and you'll be fine. So I did not fire it. And to top it off there is a leak somewhere in the crawl that we need to find and see how bad it is before we consider the new boiler.
Oh, getting up and going to work every day is such a "I wonder what will happen today to make things interesting" life.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
