Degree Day comparison info?
MasterPlvmber
Member Posts: 7
Hello All,
I'm looking for a reliable resource to compare degree day values from one heating season to another, month-by-month. There is a lot of conflicting information online and I'd like to pick one source.
Please let me know if you've got something I can access quickly.
Many thanks in advance,
John Cataneo
John Cataneo
This should help
http://www.degreedays.net/ will let you compare data for pretty much any weather station in the US, including Personal Weather Stations, which can often get you within a mile or less of the subject building.
If I'm looking at fuel usage, I download several months of daily data into Excel, then separate it out by the bill cycle dates. A bit of quick division will give you a "BTUs per degree-day per square foot" number that tells you a lot about the health of the entire building system.0 -
Swei
So what's your range of good, bad, and a submarine with screen doors in terms of btus per DD per sf.0 -
I read somewhere that US homes average about 10 BTUs per square foot per degree-day. Anything under six looks pretty good in my book.
IMO this kind of whole-system performance metric should really be used for tax credits and rebate programs. Prescriptive measures have caused a lot of trouble over the past 35 years.0 -
Home energy magazine
Range of Energy Use
Realtive Frequency
Under 5.0 BTUs/HDD/Sq.Ft.
12.2 percent
Between 5.0 and 10.0 BTUs/HDD/Sq.Ft.
39.4 percent
Between 10.0 and 15.0 BTUs/HDD/Sq.Ft.
23.9 percent
Between 15.0 and 25.0 BTUs/HDD/Sq.Ft.
14.7 percent
Over 25.0 BTUs/HDD/Sq.Ft.
9.8 percent0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
