Is There a Secret to the Search
ced48
Member Posts: 469
function on this great site? I seem to have little luck in finding what should be obvios areas of discussion.
Search the Wall
I generally find that I get better results when using the "Search the Wall" tool just above the list of topics as opposed to the general "Site Search" tool found in the upper right corner of the screen.0 -
Thanks, Jeff
I'll give that a try-0 -
Yes!
That's the answer! Thanks again-0 -
The site has two search engines working.
One is specific to Wall posts. The other (on the nav bar) is for the rest of the site. Thanks.Retired and loving it.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
