Weil Mclean EG-45 gas fired steam boiler how to clean the probe
jg69
Member Posts: 1
I am a pretty handy guy and have a what I hope is a simple question for you.I bought in 2009 a Weil Mclain EG-45 gas fired steam boiler.I have a VXT automatic water feeder attached.My problem is that when the low water cutoff light goes on my feeder isn’t feeding water to the boiler.I have drained the dirty water from the boiler but the feeder still won’t kick on to fill the boiler.I figure the next step is to clean the probe in the low water cut off but...I’m just not sure what the correct steps are to remove the probe.. clean it.. then replace it..I have attached photos so you can see what I’m working with...I think my problem is the probe is dirty..What are your thought....
can you manually feed it with the vxt
the vxt might be faulty.
I think the probe is fine, as it is detecting the low water properly.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
