Utica steam and return pipes
mikelutgen
Member Posts: 2
I have a 10 year old Utica Steam Boiler PEG150CIDE. The black, what appears to be cast iron, return pipes are springing leaks all through it's approximately 10 foot length. There are curves and couplers along the way. The pipe may be pretty old, as the house is 80 years old. What would cause this to all fail at once, and what is the most modern replacements for this pipe? I actually closed the valves off on some the radiators. could that have caused this problem?
Wet Return
If it is below the boilers normal water line, it is considered wet return, and is full of water all the time.It is common to replace the wet return when the boiler is replaced, and obviously should have been done the last time yours was replaced.Below the water line can be replaced with copper.0 -
Steam
Old pipes leak. It happens. Closing radiators shouldn't have caused it. My only first reaction, if there are a lot of leaks, is that something may have triggered it.
What kind of maintenance has been done? Do you have an automatic water feeder?0 -
auto water feed
It has an automatic water feeder. PSE&G said it was probably the back pressure from closing off some radiators that blew out the old pipes.0 -
Pipes
That is...incorrect...inaccurate...umm....wrong.
Do you have pictures of the boiler and piping?0 -
two things
1. It may just have rotted out do to natural deterioration and age or
2. If the system has other leaks, bad vents or traps or piping that has been leaking over time and the system has been adding a lot of make up water that will rot out anything below the water line quickley.
After you get it fixed monitor the water consumption carefully. you don't want to loose the boiler next.
Ed0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
