A GFCI receptacle as a LWCO
bill_105
Member Posts: 429
So it's 10 p.m. last night and 13 degrees out. A neighbors house sitter calls and says the heat is out.
The system had glycol and the make up was off. It did not have a LWCO.
What it did have was a leaking boiler drain at the boiler return. As the fluid leaked out the pump ran dry and tripped a GFI the boiler was plugged into.
The pump was ruined but the boiler lives on. What a twist! A major company was there in Sept.
Can't make this stuff up
this might be a good place for ME's "pig" setup as well as a LWCO.All Steamed Up, Inc.
Consulting0 -
Wet rotor?
You dont mention what type of circulator but it happens often. The pump windings shorted to ground and tripped the GFCI.0 -
Wet rotor?
Wet rotor?
Duplicate post from ipad0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
