Heat transfer plates
Tim_5
Member Posts: 37
Can anyone shed some information about Aluminum verses Graphite Heat transfer plates for a staple up system. There is only one brand that i can find of the Graphite but the cost verses savings is concerning.
I played around
with graphite plates a few years back. I never did come up with a good way to fasten them against the floor. Too soft and floppy.
I think Watts Radiant did finally come up with an attachment plate, but I have not tried that method.
I did infrared camera some graphite installations and it does a great job of moving the energy across even a 12" wide piece. It's an excellent conductor.
It looked good when the aluminum prices were so high a few years back, don't know how it pencils out currently.
hrBob "hot rod" Rohr
currently
I believe they are significantly more expensive than aluminum. They are making some claims I'm not sure I can support but I would consider it "at least equal" to heavy gauge aluminum plates.
whether they are worth the additional cost or not, I am not really sure.Rob Brown
in beautiful Rockport Maine.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
