Conbraco Autofill likes to go to 30psi, any tips for repair
Chris Williams_3
Member Posts: 7
This valve was setting the system to about 40 psi, yikes. Surprised the pressure relief hadnt blow yet, but will replace that also.
I adjusted it until the threads are almost out and the best I can get is around 25-28 are there any othe tricks to fix this and not have to replace it, I am wondering if its worth cracking to clean the strainer, or just swap it with a watts or something else. Thank you
Chris
Chris
change it
i would not try to repair the auto fill. replace it and for petes sake change out that relief valve!!! can you say time bomb???? rob0 -
guage?
Are your sure the guage your using is accurate? If so I would also be checking the expansion tank. Either way I would be shutting it down until it's repaired. No need to take chances. IMHO0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
