most economical scenario
Live/Learn
Member Posts: 97
Hi Wallies, Question! which is more economical a small fire (low firing rate .75 nozzel) running longer to come up to temp. or a larger fire (1.05 nozzel that reaches high point faster? Both firing rates heat my home adequately. I seemed to have burnt about the same amount of fuel this year(using .75) as I did last year (1.05) which was a colder Winter I think. Which is better for the boiler? I would think longer run times. Thanks Live/Learn
I would think the lowest firing rate
consistent with heating the house in a reasonable amount of time and keeping the stack warm enough.
Take the scenario to an extreme in both directions:
Say you put in a 2.0+ GPH nozzle. You would over-fire and waste a tremendous amount of fuel, have high stack temperatures and probably incomplete combustion.
If you put in a 0.50 or less nozzle you run the risk of condensation, low passage and flue temperatures and long firing times to get to temperature.
Same philosophy re: modulating gas- lower fire is more efficient due to higher surface area to combustion gas volume ratios. But the boilers are built to take it.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
