TM9x080b12mp11a Luxaire /York condensate issues
DZoro
Member Posts: 1,048
in Gas Heating
Had a new customer call today with a York/ Luxaire LX series furnace. This is not our install, a local guy installed a few and then went out of business. So I get the after hours call..... It is the newer series with the clear condensate box. Condensate had gotten into the pressure tube. I cleared all the condensate out, drains pan, removed inducer, checked for proper venter re-stricter. They used 1/2" pvc short drain all appear installed ok. My question is has anyone had issues with these units. I knew I didn't find the smoking gun, and was correct have a second call back. Any info would be appreciated. Forgot also lifted pressure tube up so condensate doesn't gather in it, and bent turbulators straight down behind the venter.
Denny
Denny
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
