Hot water baseboard heat
kenshel
kenshel Member Posts: 8
edited February 2017 in Radiant Heating
My daughter recently bought a house that was vacant for some time and the baseboard heat has some damage. Most of the baseboard is the normal slant fin type however in the entrance way and bathroom it has this type of radiator. This one is damaged and I wanted to try to replace it or repair if possible. I cant find anything like it on the internet. Does it have a specific name? Thanks.
  • JUGHNE
    JUGHNE Member Posts: 11,376
    Does it leak and if so where at?
  • kenshel
    Yes, on the tube with the fins right between the fins and the main assembly. The copper which looks like maybe 5/8 ths is split at both ends. if you zoom on the second picture you can see it.
  • kenshel
    Sorry the first picture shows the split best. And its more like 3/8ths copper.
  • Ironman
    Ironman Member Posts: 7,699
    Why not just replace the entire heater?
    Bob Boan
  • kenshel
    That's what I would like to do. I cannot something similar to this. My original post was asking that.
  • JUGHNE
    I see the split now. When you shop you are looking for "hot water convector" or the words cabinet heater. It is not a baseboard. Those words may get you what you need.
    Something with 2 tubes, fins about that size and the height of the cabinet makes a difference for heat output.
    kenshel
  • kenshel
    Thanks JUGHNE! that's what I needed to know. Now was able to search and found a couple that look very similar.
